Hi all, just finished wiring up my crown 1uz (using kdogs diagrams) motor into my Vl commodore. It runs like crap, starts when it wants to, doesn't idle, anyway i have brigded the two pins on the diagnostic plug, and the check engine light just flashes constantly there are no breaks in the flashes to indicate a number. does any one have an answer for that?
i have pulled plugs off the motor to create error codes to make sure the check engine light is working.
also if there are no error codes and you bridge the two pins out does the check engine light come on or not?
cheers Tony
cheers Tony
