1994 Lexus Ls400 Wiring Diagrams
Discussion in 'Wiring' started by Sam16v, Aug 14, 2012.
  1. Sam16v
    Sam16v New Member
    Aug 13, 2012
    4
    Mechanic
    United Kingdom
    Hi folks new to the site and currently undertaking a 1uz Swap into a Mk4 Toyota Hilux.
    The donor vehicle is a 1994 Uk spec Ls400, and despite some serious searching and im struggling to find the correct ECU wiring diagrams. The 1996 LS400 diagram does look very similar apart from wire colours? can anyone confirm this?
    If not does anybody have a copy of a wiring diagram that they could share? Many thanks
  2. Bushwhacker
    Bushwhacker New Member
    Mar 5, 2007
    515
    Carpenter
    Wales, G.B.
    Go by the pin numbers not the colours. The pins will be the same as the '96 diagram.
  3. Sam16v
    Sam16v New Member
    Aug 13, 2012
    4
    Mechanic
    United Kingdom
    Great stuff cheers for that, was worried there may be more differences than just the colours.
  4. samsdad
    samsdad New Member
    Aug 24, 2008
    557
    petrol and diesel mechanic
    Perth WA
    Just to be sure check the chassis/model code of the donor (if you don't have that then search the part no off of the ECU on toyodiy) if it's a UCF20 then yes the pin numbers should be the same but some UCF10 models had the same type of plug configuration and the pins are different. I think that MY (model year) 93 was the model change from UCF10 to 20 (meaning 1994 car) and MY96 was the change to VVTi. For some reason Toyota (Lexus) do seem to make changes to wiring colours from year to year, however this may also be influenced by who the supplier was for the looms for various production runs.. Either Denso or Yazaki
  5. Sam16v
    Sam16v New Member
    Aug 13, 2012
    4
    Mechanic
    United Kingdom
    Ok cheers for that, engine side of things is all wired just onto the autobox now. and seems there are few deifferences. Had a search on ToyoDiy and its a UCF10 (89-94 spec ecu) does anyone have a copy of the wiring diagram to suit, that they would be willing to share? thanks again
  6. gloverman
    gloverman Active Member
    Oct 15, 2004
    2,355
    4
    38
    mechanic
    Hamilton. New Zealand
    check engine specs and diagrams at the bottom of this page.
  7. Bushwhacker
    Mar 5, 2007
    515
    Carpenter
    Wales, G.B.
    There's nothing to wire up on the auto transmission, it's all in the ECU plugs.
    (Assuming you're using the Lexus transmission that came with the V8 of course)
  8. gloverman
    Oct 15, 2004
    2,355
    4
    38
    mechanic
    I disagree. They need the selector switches , stop switch, kick down, Neutral start etc wired. Cheers
  9. cruising
    cruising New Member
    Jul 19, 2012
    45
    advertising
    GR
    which wires i will cut out bushwaker?
    leave just auto 6 wires on black plug back gearbox
    cut rest out i will?
  10. Sam16v
    Sam16v New Member
    Aug 13, 2012
    4
    Mechanic
    United Kingdom
    Thanks again for the replies, Yes Im using the Lexus autobox, Realise that some of the Autobox wiring is intergrated with the ecu plugs but, have to agree with Gloverman, surely all the switches need to be connected to the ecu so that the autobox will function correctly?
    just need a pinout, as the 96 diagram seems to differ from the 94 one iam looking at? cheers
