Did a motor swap in my 91' LS from a 99' GS, including complete engine, trans and most of the wiring harness, including the cluster, Immo, key, ECU etc.
So I plugged everything in I could, and dash lights up, but not sure:
1. What are the symptoms of the Immo saying "no"? - When I turn the key, the Starter doesn't kick, and the fuel pump never kicks on is that related?
2. Is there maybe a shifter switch I'm missing that would prevent the pump and starter going? On my other cars, when you put the ignition on, the fuel pump runs, but this doesn't happen (no voltage). Pretty sure the wiring and relays are right to the pump, so I suspect the ECU is saying no for some reason.
There's so much wiring I'm a bit overwhelmed.. the complete engine & trans harness and main fuse box is all there and untouched. Ug. I so want somebody to wire this thing from "cold". If I can get it to run, I can figure out all the other circuits.
https://www.amazon.com/photos/share/d4Yntjv47IbsvqBW1tRuQR8iYMUk3k3qkrwEUOTgUgu
