toy4whatever
So after browsing on here for hours at a time for the past few months I've come to realize that when most people get their "custom flywheel" they never seem to post any tech or any pics of the finished product. Well I'm not going to do that.
I am building a 1990 xtra cab pickup. I am using a stock R-150F transmission with dual transfer cases. I have been trying to find info on which flywheel to use and of course keeping the cost as low as possible. http://www.lextreme.com/forums/showthread.php?t=11009
So I have decided to use a stock V6(3vze) flywheel. This flywheel is heavier than the MR2 flywheel and I can use a Marlin Crawler 2100lb clutch kit. You can usually find these at a salvage yard or CL for under $30. I paid $15 for mine. If it turns out that you get a bad flywheel don't worry. You can use it as a core and get one from a parts store(checkers, autozone) from $60-$70. First thing was test fitting and just getting a general idea of what I need to do so this would fit. I decided to drill the 8 mounting holes out with a 1/2" bit. Two reasons I did this; 1) the flywheel is already centered on the crank, 2) when you drill the holes out to 1/2" the bolt will still be to the outside of the hole and the flywheel can not move. Next I did a few test fits and you will need to take a file to a few holes so the bolts do in easily.
The next problem is getting the ring gear to line up with the starter. After looking at it I decided to move the ring gear 1/4" out from its original position. It is now flush with the outside of the flywheel.
This is where I'm at right now. The plan is to weld the ring gear in its current location and have the flywheel rebalanced. Then if necessary I will have the mounting surface milled down to put the ring gear in the correct location. I will update this soon. I plan to have this truck going by May so keep watching.
