Peewee
- 2,635
- Perth, Western Australia
Actually the reason for pushing the motor 2" forward is for the sump to clear the crossmember.Also I have a friend who's doing the same swap in a MKII and the tranny was 2inch further to the front of the car. You should need a thinner brake booster, hammer the tunnel (1UZ bell is too big) and the firewall for head clearance to make the tranny fit where it was in the first place.
If you want the gearbox to sit in the stock position then you'll NEED a custom sump (or heavily modded stock one).
I don't believe there would be issues with the brake booster or tunnel, but as its not possible to test mount the engine with the gearox in the factory position (unless you've removed the sump), its not something I'm completely sure on.
Unless the US Supra is different, then the stock lines will bolt up to the 1UZ PS pump with mods.take out the Supra lines and get them adapted to use -AN or JIC fittings. I did JIC with mine although I want to switch them over to -AN now instead. This gives you the ability to keep the hard lines in place and just unscrew the high pressure rubber lines if they go bad.
Although re-reading your post you could be talking about modding them to make it easier to replace in the future.
I'm 99% sure the early MK3 mounts unfortunately don't fit the MK2, however I'm happy to be proven wrong!BTW glad to hear you're considering using my motor mounts.
