sc400 shuts down when ac is turned on
tin said:
does anyone have any idea why this is happening.:???:
My SC used to have an opposite problem. The engine is shut down when the A/C is off at idle. It was the ECU problem from what I've been told, but it's fixed.
More than likely the A/C compressor is locking up. WITH THE ENGINE OFF try to turn the front part of the clutch by hand. It should turn with slight resistance, if it takes a lot of effort or doesn't want to move you have a bad compressor.
