I bought a '92 sc400 two weeks ago and now it's overheating (like really, really overheating). My father-in-law thinks it's a blown head gasket (nightmare)...
you have to take off the engine cover (if you have one) you will see these black things on the side of your engine around the top and on mine they are squares and if you take those off the spark plugs are down in there. I dont know if the older models like yours use distribtors or coils but those are where the spark plugs are if its coils
You can also check the oil dipstick and see if chocolate milk shake color like oil. You can also check fluid in your radiator. Discoloration or excessively low might also be a sign. Secondly, overheating during driving or you see white smoke from the tail pipe.
Could be a number of things, - thermostat, radiator, low coolant, bad water pump, blown headgasket, clogged up coolant galleries in the engine block to name a few. Most often its a leak in the system or water pump. Just take it to a repair shop and let them see what it is.
