Carrillo Connecting Rods for 1UZ?
Kinda long, not that i don't like long rods, but you'll have to get pistons with a really thin compression height. you'll also have problems with the wrist pin. but it may still be cheaper that a set of costom rods that fit the crank and pistons from a 1uz. I am planning on using chevy rods in my motor.
You need something like this...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7969732128&category=33623
The big end is 0.16" smaller than a 1UZ - offset grind crank for extra stroke...
Custom bush pin end down to 1UZ size...
Slightly shorter than 1UZ but will still have to machine piston top or move pin up - depending on stroke increase...
No specs for pin or rod end width - can't remember if the crank or rod needs machining...
Heaps cheaper than any prices I have seen quoted for a 1UZ rod...
Check out your favorite manufacturer for exact spec's and prices...
