jibby
- Messages
- 857
- Location
- Santa Monica, Ca.
I am hooking up an electical dual fan on my 1992 SC400 and need to hook into the ingition wiring and A/C wiring directly. Wanted to know the best areas as to where to feed and connect the fan wiring. I was planning on just running the fan wires to the fuse box and connect to those sources that way, but I am now wondering if that is not such a good idea? Any thoughts on this? Here is a pic of the wiring diagram, you will see that I need to connect the fan into the ignition wiring so that the fan will shut off when the car is shut off. If the fan is hooked into a direct positive lead the fan will continue to run well after the car is shut off and I do not want that. The other is when the A/C is turned on I want the Fans to turn on as well, need to wire directly into the A/C... Any suggestions? I want to make this steup as reliable as possible....
