MaxPower
- 282
- Perth, Western Australia
Thought id add a few maps that should get most people started.
They Should Be Used As A Starting Point Only, So Use With Caution. Use a Wideband AFR Meter To Confirm The Mixtures Are Safe and a Timing Light To Confirm The Spark Is The Same As Whats Being Commanded By The Wolf.
Also note that depending on what version firmware you have there may be extra settings for the ref+sync trigger mode, the attached maps will need these changes made. I am still running the old 4.6x firmware and cannot remember the correct names for the new settings. Can someone running the new firmware outline the changes that need to be made??
Ok first one, this is the basic startup map that is supplied by Wolf. Its very conservative, runs very rich with retarded spark. Does not start easily either. Good as a starting point but not much else.
