Jzs157 1uz ecu (89661-3a310, non-immobilized) - pictures and info
Discussion in 'Fuel, Ignition, Air, & Tuning (FIAT) (Members On' started by black_LS, Feb 12, 2017.
  1. black_LS
    black_LS New Member
    Jun 25, 2013
    27
    1
    Toronto
    *Title should read UZS157
    Hi all,
    I got my hands on a Crown Majesta non-immobilized ECU. Luckily, it had the three rightmost plugs still in it, so I'm able to see which wires were connected from factory as well as the wire colours.
    Click on the images below for full size.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    At first, I thought that these plugs might have been out of a different model, but then I found these pictures that confirmed they are correct.
    [​IMG]
    [​IMG]
    I read that this ECU has a similar (if not same) pinout as the Celsior/LS400, however after looking at it, some of the wires are in different places. For now I'm focusing on the rightmost plug (where immo wires would have been).
    This motor did not have a hydraulic fan, and the ECU does not have an immobilizer or MPX bus, so many of the wires are gone, but it still seems a bit odd (and minimal). Below is what you would expect to see on a Celsior.
    If I use the Celsior pinout, then the wires should be as follows:
    [​IMG]
    Present:
    1 - green - D
    10 - red - ??
    14 - black/brown - STI-
    16 - blue/white - L
    25 - green/orage - 4
    26 - violet/green - RL
    Missing:
    3 - IMLD
    4 - EOM
    5 - HP
    6 - TH-
    7 - TH+
    8 - SOL-
    9 - SOL+
    11 - MPX1
    12 - CCV
    17 - TXCT
    18 - CODE
    19 - RXCK
    20 - KSW
    21 - LCK1
    22 - TAM
    23 - PRE
    24 - MPX2
    1. What is the red #10 wire?
    2. Does it make sense that this ECU is missing KSW due to no immobilizer?
    3. What about the HP, LCK1, PRE, and TAM pins for the A/C?
  2. George_R
    George_R Member
    Sep 13, 2010
    850
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    These a/c pins would not make sense without MPX bus
    Looks like there must be AC1, AC2 pins somewhere, like it was with older ECUs
    As well as ELS1,ELS2 pins
    You can try using Soarer diagrams. SC400 that had 4.0 vvti engine had no MPX bus either
