IS-F 2UR-GSE crank / rods / block info
Discussion in 'Engine Modifications (Members Only)' started by Arnout, Apr 29, 2014.
  1. Arnout
    Arnout New Member
    Jul 7, 2007
    308
    Fulltime tuner
    Netherlands
    hi guys,
    Had the opportunity to pick up an ISF engine for cheap. There is enough info to tell you but there is also a lot on the net. Google is your friend. However some info is not easily available and I hope I can tell you some on here:
    The engine is very nice to sleep on:
    [​IMG]
    Pretty easy to disassemble. No real special tools needed. Headbolts are same socket as 2jz-gte (multipoint allen or torx. 12 points or so).
    [​IMG]
    Timing pattern is 36-2 on the crank and 3 on the cams. all four cams have a 3 on them (I think equally spaced). So the 3UZ as well as the 2jz vvti timing pattern is pretty much what you need.
    The crank unit is not on the front of the engine but it's at the flywheel (starter gear)
    [​IMG]
    Here you can see the camshafts:
    [​IMG]
    The 2UR crankshaft has less counter weights than the 3UZ. Pay some good attention to the next picture. Left is the UR crankshaft, right is the UZ crankshaft.
    [​IMG]
    The main bearings have same journal diameter. The rod journals are 1mm bigger in diameter. However, they are a LOT smaller in width.
    I tried the UZ crank in the UR casing but it touches almost everything. So they are not really interchangable (in whatever case you would assume).
    The nose of the UZ is 36mm for the front pulley. The UR has a 31mm nose. It doesnt look as beefy as the UZ crankshaft.
    The UR rods are the same shitty powder pressed material as the UZ rods. They are useless for high horsepower. Here is where I put the in the vice:
    [​IMG]
    And here is how they break.
    [​IMG]
    The UR rods have 1mm bigger big-end. They are 2mm shorter than the UZ rods (centre to centre).
    [​IMG]
    The block is open deck:
    [​IMG]
    It is a 6 bolt mains design (4 main bolts and 2 side bolts). The inner main bolts are bigger (socket 14) and than the outers (socket 12). The engine has squirters
    [​IMG]
  2. JustenGT8
    JustenGT8 New Member
    Oct 15, 2004
    2,433
    EPA
    Canberra, Australia
    It looks huge! ??
    All in all it sounds like a nice progression for an n/a V8 but for low cost boosted setups you are still better off with the older UZ?
  3. cribbj
    Jun 10, 2004
    4,731
    6
    38
    Gender:
    Male
    Consultant
    Houston, TX
    Cool Arnout, thanks for the guided tour! I've been curious about these for a long time.
    What are you intending to do with it?
  4. Arnout
    Arnout New Member
    Jul 7, 2007
    308
    Fulltime tuner
    Netherlands
    Well I want to finish my 3UZ build first. But the UR engine is just nice and it was cheap. I might build it and get rid of the direct fuel injection. But I want to convert it to flat plane then :)
  5. Mrme4u
    Mrme4u New Member
    Aug 30, 2014
    8
    1
    3
    work
    Groningen, The Netherlands
    Hi Arnout am very curious on your experience with this gem of an engine.
