Early heads on VVTi block
Discussion in 'General Discussion' started by American Locomotive, Mar 3, 2018.
  1. American Locomotive
    American Locomotive New Member
    Nov 2, 2015
    24
    1
    Fabricator
    USA
    Hey guys, a friend has a 1991 1UZ swapped into a truck, and an oiling issue caused the engine to spin some main bearings. The local junkyards usually have 1UZs for around $150, but for whatever reason there are not many around at the moment.
    The only engine they have is a '98 VVTi motor. I was wondering if we could just put his early heads/electronics/acessories onto the VVTi block without much issue? I mean I know ideally we'd just use the VVTi motor as is, but we're not trying to re-do all of the wiring.
  2. cribbj
    Jun 10, 2004
    4,725
    6
    38
    Gender:
    Male
    Consultant
    Houston, TX
    I don't know that anyone has tried what you're proposing, but JustenGT8 looked into the flip side of that, ie putting VVTi heads on an older block, and trying to run external oil lines to the heads. I think he concluded there were other passages that didn't mate up as well, so I think he abandoned it. Others' memory may be better than mine.
  3. American Locomotive
    Nov 2, 2015
    24
    1
    Fabricator
    USA
    Thanks for the info. On a related note, do you know if the early lower intake manifold will physically bolt up to the VVT-i heads? I have an idea that may allow the early electronics to control the VVT-i coils.
  4. gloverman
    gloverman Well-Known Member
    Oct 15, 2004
    2,706
    57
    48
    mechanic
    Hamilton. New Zealand
    Intake manifolds between VVti and Non-vvti are not interchangable.
  5. American Locomotive
    Nov 2, 2015
    24
    1
    Fabricator
    USA
  6. Frank Clark
    Frank Clark Member
    Apr 28, 2017
    46
    4
    8
    Gender:
    Male
    Fairview, TX
    And if the engine had an oiling issue the cam "bearings" could be shot. As the cams run directly in the heads, that means that set of heads could be toast...
