Diesel 1UZFE
Discussion in 'Alternative Fuel' started by Lextreme, Sep 23, 2009.
  1. Lextreme
    Lextreme Just call me "Lex"
    Mar 6, 2003
    12,051
    Professional
    City of Halos
    Home Page:
    Is there any major benefit of converting 1UZFE to diesel?
  2. Zuffen
    Jan 21, 2004
    5,295
    12
    38
    Retired Insurer
    Sydney, Australia
    Diesels need around 22:1 compresion ratio and direct injection to run.
    I wouldn't even contemplate the engineering and cost involved to try it.
    I seriously doubt it could be done.
    Assuming it could be done I would think Toyota would have had a 4litre diesel V8. It would have been handy for them.
  3. spf_lexus
    spf_lexus New Member
    Dec 1, 2007
    2,267
    School/work
    Murrieta California
    Im sure if we weld the head to the block with head studs on top of that for good measure? :) no doubt engineering the tight clearances fo the CR will be a fun one. I wonder if the space would be there?
  4. -Nemesis-
    -Nemesis- New Member
    Jun 23, 2005
    701
    Weighbridge Operator
    Sydney
    Alloy block vs combustion pressure of a diesel?
    Is there such a thing as an alloy diesel?
  5. shallis2
    shallis2 New Member
    Nov 18, 2005
    44
    technician
    gold coast, Australia
    the landcrusier 70 has the 4.5 l turbo v8 diesel.
    big big motor though
  6. spf_lexus
    Dec 1, 2007
    2,267
    School/work
    Murrieta California
    Incorrect, the 4.5L (1FZ-FE)is an Inline-6 configuration. Iron block, aluminum head and it never came with a turbo. The 2010 tundra/Landcruiser's new Diesel is a 4.5L and is a V config, with twin turbos too, was that what you were talking about? I suppose if a 4.7 2uzfe was used instead it would mimic the 1fz-fe pretty close. We would need a lot of engineering to fit 30:1+ CR inside, and I am guessing to say the valves will limit the amount of space we can eliminate with the piston dome? I'v tore apart a diesel or 2 and can say that there isn't much room for anything at TDC, although the short valve lift/height on the early UZ only helps. Also the Iron will deal with the higher heat much betetr than the aluminum block. A frankenstein swap with 1uz heads, 2uz block could be a viable solution if any bored engineers have the balls to try it ;)
    interesting Idea IMO
  7. shallis2
    shallis2 New Member
    Nov 18, 2005
    44
    technician
    dont know my toyota models but toyota do
    http://www.toyota.com.au/landcruiser-70-series?DCSext.LPLink=LC70|Model
    and there is 2 of them at work and they are definetly v8s
    • 4.5 litre V8 turbo diesel engine
    • Variable vane turbocharger with intercooler
    • DOHC (Direct Over Head Camshafts) with 32 valves with common-rail direct injection
    • 151kW power – Over 20% better than the previous Turbo Diesel
    • Fuel economy (L/100Km)* – 11.9L Troop Carrier & Wagon, Cab Chassis 11.5L
    • Class-leading 430Nm of torque
    • Meets strict Euro IV emission standards
    • 5 speed manual transmission with High/Low range
    • Over 1500km range for vehicles fitted with 180L tanks (Cab Chassis and Troop Carrier)
  8. -Nemesis-
    Jun 23, 2005
    701
    Sydney
    The V8 diesel has been out for a few years in Aus spf, guess we win for a change....
    I still can't see the combustion pressures of a diesel lasting in a typical petrol alloy block. It will blow the sides out of it.
  9. Zuffen
    Jan 21, 2004
    5,295
    12
    38
    Retired Insurer
    Sydney, Australia
    I'm with Nemises on this.
    The iron sleeves were made for much lower compression ratios than a diesel runs.
    If you have a lazy $100,000 perhaps, just perhaps, you could make it happen.
  10. Merxus Benz
    Merxus Benz New Member
    May 6, 2009
    42
    Duty Manager, Hotel
    Melbourne, Australia
    All the v8s i know of in the landcruisers use a cast iron block. That would be easier to convert.
  11. XR8tt
    XR8tt Moderator
    Jul 8, 2007
    2,761
    36
    Lineworker
    Sydney Australia
    Subaru's new new boxer diesel is an alloy block..
    I cannot see too much of an issue the manufaterer making diesel's in these style of blocks ??..
    Yes some re-engineering needs to be done.. But in the past diesel's where regarded as heavy duty motors..
  12. hungryforinfo
    hungryforinfo New Member
    Nov 17, 2006
    368
    mktng
    brisvegas
    could use a diesel block. I think it could handle it, as for the engineering required, don't bother a 4.5L twin turbo toyota Diesel can be had, check out VDJ200 series, for the twin turbo and single turbo is on VDJ70series.
  13. hungryforinfo
    Nov 17, 2006
    368
    mktng
    brisvegas
    oh yeah, around $15k for the motors
  14. Zuffen
    Jan 21, 2004
    5,295
    12
    38
    Retired Insurer
    Sydney, Australia
    Interesting we all speak of 22:1 compression ratio but if you'r running 9:1 (like me) and then run 22psi boost (like me) the actual compression ratio is over 22:1 when on boost.
    On that basis the block/rotating assembly can sustain the compression.
  15. hungryforinfo
    Nov 17, 2006
    368
    mktng
    brisvegas
    I was thinking that exact same thing, then its a simple matter of the right heads/cams/valves/fuel inlet and tuning, which would be acheivable, but cost prohibitive. VD series for the win.
  16. Zuffen
    Jan 21, 2004
    5,295
    12
    38
    Retired Insurer
    Sydney, Australia
    Agree a pointless excersize when so many good, and proven, diesels are available at far less cost.
  17. exhaustgases
    exhaustgases New Member
    Jan 14, 2015
    22
    Mechanical machines
    Here
    Not true, there are diesel engines that are running under 14:1 to control NOx.
    http://www.popsci.com/cars/article/2013-02/how-mazda-reinvented-diesel-engine
    Just one example.
  18. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    263
    2
    18
    Not much
    Bangkok
    whatever
    Toyota has diesel V8s, been around for close to 10 years now.
    4500 cc turbo charged, comes with 1 or 2 turbos.
    Great stuff. roughly 260 hp roughly 750 Nm.
    As far as I know they can be found in large Landcruiseres, Lexus 570 and some pickup models.
    These mills may be found almost all over the world.
    But not in the 2nd largest Toyota producing country, Thailand. Pisses me off, 'cause
    I want a 1VD and I stay in Thailand.
