1Uz-f20T Starlet kp61
Looks like a UCF20/21 motor so will need the 28/16/22/34 pin ecu with the header plug offset to one end of the ECU. NO EGR. I have several but dont have the 28pin plugs at the moment. See if you can find one locally first. Cheers
Thank you :)
Will some of these fit my engine?? Do I need some more parts than just the ecu to make it run??
89661-50303
89661-50230
89661-50221
89661-50235
They all have the right pin-numbers.
Two ECUs listed for UCF 20/21
89661-50241 from 01/95 to 08/96
89661-50380 from 08/96 to 06/97
After 06/97 I beleive they went VVTi so this should narrow it down a bit for you but I think that given what you're doing an aftermarket ECU might be a better bet for you
After 06/97 I believe they went VVTi so this should narrow it down a bit for you but I think that given what you're doing an aftermarket ECU might be a better bet for you
Thank you :)
I would like to use a standard ecu. Less trouble later, and just a dyno test with adjustment costs about $1500 Norway
hey gloverman i have a 28 pin plug
some people think 100 bucks is abit steep for them but i cant find em anywhere
thats y they r expensive
mazda rx7 very late models have same pin configs
think around 2000 models maybe try them
yer part number t105 in my box of junk
hehehehe
sorry i have no idea
the reason this part is expensive is because im sick of people buy motors from
cheap importers rather than guys who really know their stuff and u pay bit more but u get everything
i have 2 x 50 lt boxes with plugs and i only have 1 of these so good luck finding one
try tweak it in usa
Feedup
can someone please help me with wiring diagram how to connect do i need the igniters,(the ecu has 3 plugs, 34P, 22P and 28P) to get the engine running. want to use manual 5 speeds cressida box.
mail to [email protected]. `
PLEASE HELP
