ranger2339
- 174
- Minneapolis, MN
I want to run the R154, but if the pins only fit in three of the six holes and those are the holes for the W58, then Ill use the W58..
Here are the pins in the only holes that they fit in.
Here is a pic of one of the "other holes" with a pin that wont fit in it, due to the width of the pin vs the holes width being to narrow.
I tried to measure the depth of the "other hole" with the stick here and compair it to the pin, as you can see the hole is way to deep for the pin.
Here is the stick that I used to measure the deep "other hole" in the hole that fits with the pins I have.
Hope this helps?
Josh
Hope this helps?
Josh
