Water Coolant Change
Michael Bruce
I would like to find out how to chage the water coolant, with daigrams if possible. As I understand, it's not to easy getting all the coolant out, but possible if you can locate the drainage points on the side of the block, hence the request for a relevant diagram.
Best wishes
Michael
It would be good if you drain the block radiator fluid and use a pressure hose at the radiator cap and give it few shots to force out all the fluids in the block, hoses and the radiator.
Actually with the compressor method. You might not have to get to the block drainage. You can loosen one of radiator hoses and use the compressor to force it out. Once u fill in the coolant, make sure all the air is out otherwise you will over heat the engine.
