toyotasrfun
alright
so here's what i am wondering
if i use the stock 1uzfe computer and harness and only change the transmission to manual leaving everythign else stock.. do i need that part of the harness?
I am able to get a harness from a local wrecker along with the computer.
I was thinking to cut the section that seems to go down to the transmission.
Is this a bad idea?
I am planning to use a 7mgte from a mk3 supra.
Will cutting this section of the computer cause problems?
please let me know as I'm hoping to put the engine in using only the stock computer for now.
Later down the road I will be looking for more power and tuning and also go the direction of building the motor. I was hoping to go turbo but I feel that a high compression buildup would suffice just fine.
I am putting this engine into my 1972 toyota corolla (much like the flea) only I'm building a car for turning and he's building one for straight lines.. Yes i could go with other engines.. but why.. this is something i've wanted to do for a little while now.. when I saw that the flea had done it i tried very hard to stay away from the idea.. but finally i've stopped lying to myself and the idea is coming together..
AAAAnyway
will this work?
has anyone done it?
is cutting the harness a bad idea as i will be keeping everything stock for a very long time?!
let me know
thanks
cant wait to read the replies
Is this a bad idea?
AAAAnyway
will this work?
has anyone done it?
let me know
thanks
