Big
- Messages
- 376
- Location
- New Zealand,Queenstown
Gidday everyone..
been a while and now guess what.. I'm seriously looking into FI my lex..couple questions though for the guru'z here..
SC injector size is 251cc on standard computer..I also believe from what i've read that if using a RRFPR it CAN help with small boost..up to 7-8 psi keeping everything standard and basiclly increasing the fuel pressure going through the injector,but my question is... If i use some top feed
275cc high impedance 13.5 ohms injectors , would the standard ECU be able to utilise them only being a small % increase from standard..? and doing away with a RRFPR all together..?with 7-8 psi boost..? I have a plan but all i'm wanting is tq not top end..I'm going to use the M90 with a custom manifold setup from which I've thought about a long time.
Any thoughts would be awesome ,as usual this is going to be on a shoe string budget until i can get a new ecu then i'd dyno and do a proper tune.:feedback: thanks guys..
