New to the game
PARTS FOR SALE: Limited availability on 1UZFE EGR Delete Kits, Torque Converters and Supercharger Fish Brackets. No turbo kits. Email for info: [email protected]
SPDMN90
Gulfport MS.
I just got my 1UZFE for my targa top supra and I have a few questions to further my research. I know I can do a search for these items but I am on a computer in Afghanistan and I don't have that kind of time. If there is any thing else I need to think of that I need to do to my car for this conversion let me know.
Were can I get the specs on the motor?
Were can I get motormounts for a 89+ Supra due to the diffrent subframe?
Were can I get a factory picture of the motor out of the car with everything mounted on the motor including the powersteering?
Can I use the factory headers on my car or will I need to get after market set?
Can I use my supra altinator or will I need to change over to the LS400 altinator?
What fuel pump will I need to put in my tank to run this motor?
These are some questions I have for right now and I might have more later. Thank you for the help.
Just call me "Lex"
City of Halos
http://lextreme.com/misc.html
Few guys made them here
http://lextreme.com/misc.html or google
IMF, SS or Tundra
Not sure, but I would not be surprise. Toyota parts are interchangeable.
Other can answer that but stock Supra should work
Welcome to Lextreme
milisakeracing
Kalamazoo, MI
IMF, SS or Tundra
Yes, the factory manifolds will fit in the Supra. If this is going in the MkIII, you'll probably need to remove the heat shields on the driver side and the shield over the steering shaft as well.
Yes, you can use the Supra alternator but why? The Lexus alternator provides higher current. If you stick with the Supra alternator you'll either have to make a bracket to keep it on the same side of the engine bay or you'll have to extend the wires to the opposite side of the engine bay. If I recall correctly, same connectors are used but wire colors may be slightly different.
Welcome to Lextreme
David is right, stock pump can be used. I already had the Walbro 255lph pump since it was upgraded on the car before I purchased it and swapped out the 7M-GTE turbo engine for the 1UZ-FE. However, it is good to have it since I won't have to upgrade it again for a basic turbo setup which I am planning to put together and install one of these days.
Welcome to Lextreme! There are lots of helpful people around here.
SPDMN90
Gulfport MS.
Does any body have any pics of motormounts that will fit a 90 supra and who might be able to eather build a set or I can buy from?
