Hall effect sensors 1uz
nateb55
has anyone converted a 1uz crank and cam sensor to hall effect sensors? I know it is possible to run with the standard VR sensor but for my particular ecu would require an additional table to create and calibrate so going with a hall effect would be much easier
thanks in advance
Can't see why not, all you need to do is devise a method of mounting the sensor or select a sensor that can be made to work on the existing mounting points.
Not sure about how you would mount the magnet but that's the fun of modifying cars.
