Parts FS: V8 Engine and Trans - 2 sets
aliga
$350 local pickup per set (located in Queens, NY zip is 11432)
I will not ship, but can put onto a pallet, if someone arranges for pickup.
89k miles on motor set, pulled out of a 95 sc400.
Email me at [email protected]
getimage.aspx
getimage.aspx
so is it 350 for motor and tranny? and would this be a direct replacement for my 1990 LS 400? any info would be appreciated. thank you
i have trac control and factory air suspension if that makes a difference
Alex
It will not be direct. You need to transfer the LS400 oil pan to the SC400 engine. Looks like the engine above also have trac control. AS is not an issue at all. Just swap out the oil pan and u are set. However, since the motor is out. Its wise to change the water pump and timing belt along with timing pulleys. Those parts are expensive due to labor. If i am you, i would replace the starter too. Its a peace of mind.
You will also need to swap your alloy engine mounts onto the SC engine as they are different.
Also the air co compressor on your engine is different to the SC.
Lastly the exhaust manifolds may need swapping. Not too sure on that.
Note the resevoir on the P/S is different but easy to swap.
