- Messages
- 5,632
- Location
- Sydney, Australia
Just so I don't get bored my car decided to throw a few codes at me.
22 Water temp sensor
24 Air intake temp sensor
41 TPS
47 Secondary TPS
I can ignore 47 as I don't have a traction Control engine so that's easy.
22 & 24 are interesting as I've checked the sensors and both are within range of the workshop manual.
I've checked continuity to the ECU and to the chassis and all read good.
I also have voltage where it should be.
41 the TPS is an easy fix and I just need to adjust it but the car idles at 650rpm so it can't be too far out.
The car runs with a slight stumble below 2,000rpm but gets up and starts to go well at 3,000rpm and is going very hard above 4,000.
I've tried swapping the AFM/MAF to no effect. I've checked the contacts on the sensors and the ECU and they look clean.
At this point I'm starting to run out of ideas, so any suggestions would be most appreciated.
41 TPS
47 Secondary TPS
