1uzfe diff
40rsed
Looking for a LSD diff I can put into my celsior to handle a bit more power as it is spitting diffs out on dyno runs only at 30 % power with a 1uzfe 4.0 litre , need to now if any one has put a lsd centre into a celsior (ls400)?
An LSD will load the centre up even more.
If the car spins a wheel/tyre it's unloading the diff.
If both tyres hod on because of the LSD the load on the diff increases as the effective fuse of loss of traction is gone so the next weakest link will fail and that will be the diff.
The real solution is to use a tougher diff either open or LSD
I’m after a LSD diff that can handle 1400 ft pd of torque to put into a ls400 1990 mod is there a diff I can put in with out to much fabricating?
