shatcher80
- Messages
- 5
- Location
- Augusta, GA
I have a 1991 Lexus Ls400 and recently had the fuel pump replaced. Low water temperature light kept coming on for about two weeks, always filled it with water but couldn't find the leak. One day car just runs completely hot so I pull over at a gas station and have it towed to a mechanic shop. He tells me my water pump is gone bad, needs to be replaced and also he would replace the timing belt since that would have to come off as well. After two days everything was put back together but car wouldn't crank and spark plugs were not getting spark. I suggested he redo the timing because car was runnning fine before the timing and water pump were changes. Now in one week and the work is finished the car will turn over but will not start. The mechanic explains to me that he has done the timing twice and assures me it is correct. Went by there yesterday and he said the spark plugs were wet but once he dried them off they continued to get spark but car wont fire up. He is puzzled and not sure what the problem can be. Any suggestions?
