Wanted WTB 1uzfe Crown Air con compressor
bea_vis
Tamworth, NSW, Australia
As title, seeking 1uzfe from a crown i believe(will remove this weekend to confirm).
Working order preferred can also do exchange if preferred.
PM if you know of 1 please, Im located Tamworth NSW, AU
Cheers -beavis-
You can use an AC compressor from any 1UZ, unless you specifically need the Crown one (Crown one has the speed sensor in it, where as Soarer/Celsior does not).
Hi,
I have an old A/C compressor off an old 1UZ Soarer (92 model I think), it's been off the motor for a few years now, but if you want it, come and get it. I live in Medowie, near Newcastle. PM me for details. (I'm also on Toyomods under the same user name):):D:cool:
Yes the crown ac pump has a knob on back that sticks out abit
I made my engine mounts without ac bolted up then the compressor
Would not fit because of this knob
I ended up drilling a 20mm or so hole in engine mounts/brackets
Which then made compressor slide into the whole
This was in a bilux aswell
