wont run with mass air hooked up (arm)
Zukijames
Lehi,utah
finally getting my swap pretty much wrapped up .. it has never ran with the mass air but i thought maybe that was because I did not have any o2 sensors
So today I bought o2 sensors plugged them in and mass air and it wont start unless I give it throttle and wont idle
unhook mass air and runs way too rich .
exhaust is coming strait out of exhaust manifolds could that be the issue ?
check that you run the right sort of maf (compare part ## of ecu and maf at toyodiy.com,whether they come for the same car)
also check that the maf is used in the right direction, and there's no major air leaks etc.
