What connectors are these? can Anybody tell me?
ak47prince
Malaysia
Firstly ..so sorry to disturb everybody again. I need to know what these plugs does. ECU-89661-50050, 26p-16p-22p-26p.
1) there's two very identical 4 pin connectors. with the same wire colors too. one of the similar wires are the Blk/Red with 12v when switched on.. they are situated behind the engine.
2) the second connector is the crushed one situated and share a common harness insulator with the battery + terminal . with 4 pins white/green-yellow/green-black/white- and yellow/black. looks similar to the wire colors from the igniter wires.
3) there's two black/red wires from the 26 pin ECU plug pin 4 and 17. and in the same connector,there's also this 2 big white /black ground wires. I wonder,do i need to supply 12 volts to these 2 Black/reds ? because according to the 'Tonyd 's ' diagram ,one only need to supply the 2 black/red wires of the 22 pin plugs...
Thanks everybody,
andy
