1. Brembo is
NOT the best-far from it. I would rate brembo like a bose speaker system. Waaaay overrated, no highs, no lows, must be bose. Marketing name branding goes a long way. I can't tell you how many times I have heard "Just because x______(insert brand name here) uses it it must be good." NOT TRUE. Brembo in my opinion is lower middle of the pack. Obvious clues are the gentleman ON THIS THREAD who said he
HAD brembo's and said it was marginally better than stock. There is a reason stock Supra brakes will outperform all the other brake kits (including 6pot AP-racing)with just a pad and rotor upgrade.
here is proof
2. "The Best" braking system you will definetly have to pay for. You might want to consider what your braking needs are and start there. If you are not doing laps on a high speed oval at 200mph, you probably don't need "the best." BTW, the best brake system for any amount of money is this one:
BEST BRAKES These baby's are designed from aircraft brake design. They are on Winston cup cars, sprint cars, lemans, GT and the like. Overkill on your application IMO.
3. If I were you, Get brand new SupraTT fronts and rears, properly vent them, get ss lines, and get good slotted rotors with porterfield or hawk blue pads. BTW, EBC's have caught fire on my car. I would bet you 1000 dollars you couldn't max that combo out on the track if you tried your darndest. On Slicks.
4. Speaking of slicks, if you hit your brakes as hard as you can now, and it locks up at 100mph, you don't need better brakes, you need better tires.
A rule of thumb- If you can activate the abs system at any speed, you don't need more brake horsepower. That would be a need of more tire.
You can only brake as good as the tire on the car. If you get to the point of maximum braking and the tire isn't locking up, (no ABS activation) You are lacking the required BHP to stop at maximum of the tires. THEN AND ONLY THEN do you need to upgrade your brakes to something more powerful. If you are experiencing fade, larger vented rotors and upgrade the compound of the brake pad would be the right choice. Adding more friction(i.e. bigger brakes) because your fade now is silly, that doesn't solve the problem. The only way the bigger brakes would solve the problem of fade is if your big brake kit had a larger rotor and more aggressive pad compound than stock. So either way, you will need bigger rotor and change the pad compound, big caliper upgrade or not. Up to you to spend a $400-1000 on pads, rotors, and proper venting with ss lines, or $4000-7000 on something that may not be better than what you have.
my $.03
