wat is the offset on oem wheels
petre101
Renick, WV
I'm putting 19's on my 92 sc400. wat i'm wondering is the offset of the original wheels. i'm hoping to put 19x8.5 on front and 19x9.5 or 10.5(wat i prefer) rear. wat offsets will work on front and rear and not rub with them sizes?
Stock sc4 offset I believe is 55mm. If you want to run 19X8.5 front depends on the wheels you can go from 36mm or 38mm offset up. For the Rear 19X10.5 is pretty hard to find the right offset that fit without rubbing or fender modification but it is do able. 19x9.5 is easier to fit with some offset like 38mm to 42mm.
I think stock SC offsets are +50mm.
If you use the wheel offset calculator:
http://www.1010tires.com/WheelOffsetCalculator.asp
You can calculate which offset would make a 10.5" wheel work.
You can probably go with 10.5 +40 and be safe. It's always nice to have your fenders rolled to gain some extra clearance.
I am using 19x9 +25 fronts & 19x10 +25 rears. Fender rolling required.
You can use my specs and go higher on the offsets to not worry about fender rolling/shaving. Such as fronts +35 and reas +35-40
Good luck!
