Thermactor
- 541
- San Diego
It was water - it was clear and there was no smell other than the smell of the trans fluid.- and I don't think it was circulating inside the unit. As I cleaned up the gasket surfaces and stood the transmission up on its bellhousing, the fluid seeping out of the pores of the valve body was dark, like old trans fluid, but not milky. I might get lucky on this one. Close inspection of the components visible from pulling the pan indicates a clean transmission with no rust or deposits. There wasn't any crud buildup on the pan either besides the floating layer of water. My guess is that the trans sat outside for some time and water got in through the dipstick tube or cooler lines.If the trans is shifting into all gears I would think it's still fine. Change the filter and use fresh dex III and cross your fingers. Is it water or coolant? If it was coolant contamination it will turn white and will smell very foul. Oil will float on top of the water so there's a chance that the trans oil pickup was circulating the oil and not the underlying water that will settle at the bottom of the pan.
The a341e is a pretty durable unit. They cost $150 from junkyards for a reason.
Anyway, it's airing out in the garage right now. Tomorrow I'm going to put the gasket and filter on there, and continue pulling the old trans out. Wish me luck
