Arnout
- 307
- Netherlands
hi guys,
I was playing with a few engines I have disassmbled here in my workshop. I got the RB26 engine, 2JZ engine and the 3UZ engine.
I removed and took apart all the oil pumps. The RB oil pumps are known to crack (the inner rotor) because of the big free play this rotor has on the crank collar. At certain RPM's the pump starts to swing on it's own harmonic frequency and this causes the inner rotor to crack, this is all combination of the frequency, the free play of the rotor on the crank collar and the inner rotor not being very strong.
Looking at the 2jz engine they dont have this problem as the oil pump is driven by a splined collar with no free play.
Then I looked at the 3UZ. Also only 2 flat pieces driving the oil pump. And even worse; the free play is also big. Now these engines tend not to rev that high as the RB and JZ engines can, but still I am worried about the oil pump to explode one day.
Has anyone seen this problem / had this problem?
I can make a few small movies so you can all see the free play on the connection crank -> inner rotor
