CarlosR347
- 78
- Hialeah, FL USA
Hey guys i went Turbo and 5Speed on my SC400 and I recently installed an AEM FIC8, but the car is in limp mode (im guessing) once it reaches 3800-4000 it back fires and its like it starves for fuel, my AEM wideband shows my AFR go from 13.8 (2k) 14(3.1k) 15(3.5k) 17(3.8k) and --- at 4K so its like it runs out of fuel, so the first thing i did was up the fuel real quick and even at 99% increase at the 3.5-4k range it did the same thing.. i started it in the morning and was hard to start and then in the afternoon it wouldnt even start.. i jumped E1-TE1 and the codes were a bit erratic but i think it gave me code 12, it would flash once and then twice really fast, I recently had redone my Cam/Crank sensor harness to the nearest connector and everything was fine.. I install the FIC and i get this problem, I even tried running it N/A thinking maybe the Turbo was causing it, and still the same issue.. Any helps would be great guys thanks!
