Tundra 2UZ turbo kits
EPO
Hi All,
I would like to turbocharge my 2001 tundra. I also plan to give it a new bottom end and lower comp ratio pistons to handle the increased boost. I have begun doing research into options, but have come up short on turbo kits, engine management and transmission options. I know STS in the past had offered bolt on kits for the 2 UZ-FE but it appears they no longer offer or make them. What other options are out there for tundra turbo kits?
There are several turbo kits on ebay, some look better than others: https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=tundra+turbo&_sacat=0
You can use a standalone or get a piggyback. On my Land Cruiser 4.7L I am using a MAP ECU3:
Other things I would do for turbo kit:
AEM E85 compatible high flow fuel pump: https://amzn.to/3fQUifa
Enginetech coated pistons: https://amzn.to/31etnWC
Fel-Pro headgasket kit: https://amzn.to/37YaVCV
Wideband gauge: https://amzn.to/2Yu7nVR
Oil Catch-can: https://amzn.to/2Veha06
Nordlock washers to keep exhaust manifolds from backing off: https://amzn.to/3fQUCuo
J1000, is this a piggyback unit, or does it do it all? Are you using the factory ECU for the box? Is it auto or manual?
