Trade Toyota/Lexus ECU reprogramming
George_R
Well-Known Member
Staff member
Russia, Moscow
I'm starting to offer new service, in addition to immo off (see http://www.lextreme.com/forums/showthread.php?t=16344)
Currently supported are
Lexus LS430 / Toyota Celsior UCF30 , 6a/t only
Lexus GS430 / Toyota Crown Majesta UZS186, 6a/t only
Lexus IS250 / Toyota Mark X
Toyota Tundra 5.7 , all years
Toyota Sequoia 5.7 , all years
With more to come. So far I can only do ECUs dated from 2003 onwards
OLDER ECUs ARE NOT SUPPORTED
ECU should be sent to me for reflashing
Currently available options:
-power/torque increase
-disabling catalytic converters monitoring, sub o2 sensors, charcoal canister monitoring
-disabling a/t related DTCs and fail safe modes for manual transmission install
power/torque increase is achieved by changes made to the following parameters: (ignition advance map including base calibration, max retard values, and THA/THW correction as well as adjustment per VVT position ; fuel map including base calibration and dynamic enrichment values; changing VVTi base maps)
Price is $400 USD for any list of supported options
A friend of mine actually does this to *OLDER* ECUs which I can not care less for
These use 8-bit Motorola-derived processors
Newer ECUs like those for 1UZ vvti and 3UZ (2000-2003) use 16-bit controllers, but these seem to be mask ROM programmed (i.e. one time programming that is part of crystal manufacture process). Apparently these can be run off external memory, like this is done in my Tom's tuned ECU for 1uz-fe vvti. But the method ultimately needs desoldering of old processor and installing some add-on board.
Even if someone manages to read factory firmware from such ECU, I would not bother even trying to do that lot of precise handwork. In fact I even don't rely much on my Tom's ECU and always have a spare factory ECU in my car.
What I offer for newer ECUs is purely software thing and that's reliable enough to me.
Hi i have fitted a lexus 1 uz v8 non vvti and autobox which is all wheel drive into a 2002 Grand jeep cherokee body which i reconstructed as a pipecar.I have a dictator ecu on the motor.The problem is the autobox which spitstronic unit do i need for autobox to shift gears it is a 4 speed box.I removed the frond diff that was running through the sump,fitted standard sump and connect transfercase to front diff of jeep.It seems to pull only in one gear i thought that i could shift gears manually
