Timing belt is jumping! Help!
PinelochTundra
Houston,Texas,United States
I have 2uzfe with timing 100% correct with new timing belt, everything is lined up and timed correctly. I hand turn the motor about 3 times and none of the marks are lining back up but they were when I timed it. I don't understand. Unless this is natural for the 2uzfe(non vvti). Please help. This is my daily and I need to get it running.
you need to turn the motor over an even number of times as the cams travel at half the speed of the crank. It won't line up the marks on the timing belt again unless you are ready to turn it over alot. You should be lining it up on the marks on the crankshaft pully / timing cover and the camshaft pullies and backing plates. Cheers
