Specifications
Type: 6.2L Gen-IV V8 Small Block
Displacement: 6162 cc (376.0 ci)
Compression Ratio: 9.1:1
Valve Configuration: Overhead Valves
Assembly Site: Silao, Mexico
Valve Lifters: Hydraulic Roller
Firing Order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x Stroke: 103.25 x 92 mm
Fuel System: Sequential Fuel Injection
Fuel Type: Premium Fuel Required
Engine Orientation: Longitudinal
Valves Per Cylinder: 2
Bore Center (mm): 111.76
Engine Mass: 467 lbs (212 kg)
Horsepower:
540 hp (403 kW) @ 5400 rpm (Preliminary/Estimated)
Torque:
540 lb-ft (732 Nm) @ 4000 rpm (Preliminary/Estimated)
Actual power levels may vary depending on OEM calibration
and application.
Fuel Shutoff: 5600 rpm
Materials:
Block: Cast Aluminum
Cylinder Head: A356-T6 Rotocast Cast Aluminum
Intake Manifold: Cast Aluminum
Exhaust Manifold: High Silicon/High Moly Cast Iron
Main Bearing Caps: Nodular Iron
Crankshaft: Forged Steel
Camshaft: Hollow Steel
Connecting Rods: Forged Powder Metal
Additional Features: 1.9 L/rev Supercharger
Integrated Single Coolant To Air
Intercooler
Requires closed cooling system
Piston Oil Spray Cooling
Direct Mount Ignition Coils
Horsepower:
Torque:
and application.
Materials:
Intercooler
