kc95sc400
- 524
- Charlotte, NC
Ok, so I've changed my setup quite a few times and I'm not sure which is best.
Before I go into a whole lot of details on the different setups...when I had removed all the piping to run the above pictured setup, I had found some blockage in the pipes from the SC to the IC. I'd rather not say what it was (too embarrassing) but I assure you it was significant.
Without the intercooler (above setup) my temps averaged 50-60 degrees above ambient temps. Add another 15+- degrees with 6-7 psi. Drivability was great. I had seen 10+ psi on accident at one point. I don't think fuel was an issue but I really didn't see what the AFR was when I hit the 10psi. No problems, keep in mind the ambient temps have been from 50-60 degrees lately.
My ONLY concern with the setup is the high temps. More worried about what they will be in the summer. Otherwise, drivability and throttle response are awesome. Boost very easy to achieve. From everything I have read, 50-60 degrees above ambient is not bad at all. I've seen some people saying that they see temps upwards of 200 degrees above ambient. Do keep in mind that my temps are measured right before the throttle body, not in the manifold, which likely has higher temps.
With the intercooler re-installed....my temps average a mere 12 degrees above ambient. Throttle response doesn't suffer very much. And on a test drive I made 8-9psi. Boost response is slower, boost is harder to achieve. Here's the biggest problem, drivability suffers quite a bit. With the IC and all the piping, the AFR surges rich while coasting. Without the IC, the fuel cut seemed to work great. The shift patterns of the transmission seem to change, for the worse. Without fuel compensation, the AFR is pig rich with boost.
I am very torn on this whole thing. I really preferred the non IC setup as far as drivability, but I was always worried about what the temps were. Plus concerned about what the temps will be in the summer.
Another thing to note, with the non IC setup, my temp sensor was installed into some of the metal piping before the throttle body. With my current IC setup, it's installed into plastic. Heat soak MIGHT be affecting the readings of the non IC setup.
Please, if anyone has any input, suggestions, experience...please let me know. I'm thinking about going back to the non IC setup because the car is more fun to drive.
Thanks,
KC
Thanks,
KC
