Sorry for the lack of updates.
I am still having my fair share of issues. LOL.
I had been going very lean with boost. I put in a Walbro, replaced the FPR, and replaced the engine coolant temp sensor. Better, but still had the problem.
I also tried a different MAF sensor, no change.
I figured out that the block off gasket I made for my EGR burnt through, fixed that but still lean.
The problem I had with going rich while idling and cruising was due to my lack of an O2 sensor on bank 1. I jumped the oxy1 and oxy2 terminals in the data link connector under the hood. Basically, the bank 2 O2 sensor is sending info to the ECU for both banks.
Just this past weekend, discovered that my EGR block off was STILL causing me problems. I also discovered that the injector orings that seal the injector to the manifold were leaking pressure. I replaced all the orings and decided to install the 315's I've had laying around for a while now.
I now have plenty of fuel with boost, up to 6psi anyway. My idle and cruising AFR are kind of all over the place now for some reason though. Tried with two different MAF's and also tried running in speed density. If I unplug the MAF and my fuel computer, my idle and AFR are rock solid at idle. The idle AFR has always been a bit weird while running in speed density and I think I have two bad MAF's. I'm going to use a smoke machine tomorrow at work to double check for vac leaks. If I can't find anything, I'll assume that I do indeed have two bad MAF's and I'll attempt to tune the MAFTPro running in speed density.
Some links for more info.
http://clublexus.com/forums/showthread.php?t=312268&page=14 start on post 208 for some new info and some pics.
http://clublexus.com/forums/showthread.php?t=338293 I suggest reading this thread through, there is some good info there. Also some internal MAF pics.
KC
havent heard much about your car lately kc. hows it going did u sort all your probs out yet.
as for my project buying a house is on the top of my list of things to do atm so its kind of on hold till i get that sorted. still slowly collecting bits though.
