Matty Dog
- 29
- Wellington, New Zealand
I am in the process of building something along the lines of an over-sized, 1UZ-powered Lotus Seven, using front and rear suspension from a Mk3 Supra. It looks like a strong, well-designed set-up and should suit my purposes well after trimming some of the excess weight off the sub-frames.
My one concern with the Supra rear end at the moment is the location of the forward-facing trailing arms. In their present location, the front mounting will intrude directly into the space where the driver and passenger would sit.
I want to move the front mounts for the trailing arms outwards, but I can’t figure out what effect this will have on the car’s handling.
I have talked to a couple of knowledgable people in my car club who clearly have a good understanding of how suspensions work, but I was not able to reach a conclusion.
One said that as the suspension only has limited travel in the sort of car I am building, so I could put the mount where I want it to be and it would have a negligible effect.
The other guy suggested that the current location of the trailing arm would probably induce a little understeer under hard cornering, which isn’t always desirable, but that changes should be thoroughly researched.
If the car had a regular double-wishbone suspension, I think this would be simpler to resolve, as I could just mount the trailing arm on the trajectory line from the two lower wishbone pivot points (sorry if I’ve lost anyone here, I’m a mouse-clicking banker, rather than an engineer!).
Being a multi-link set-up, I just can’t figure out what the implications of any changes will be.
The picture below is from www.MA70.com and depicts the Supra rear suspension to give you an idea (hopefully!) of what I am working with.
