Justen,
i seen ur reply on the other thread regarding pulley sizes, from what i calulate from my little spreadsheet here, you should be getting around 18psi boost?
so slippage or heat may have just drop the psi down a little bit, but if run gilmer drive an sort out the water injection that will improve some.
by the way, with gilmer drive installed, the car will sound really mean from idle
____________________________________________
:sgrin:There is No substitute for cubic inch, except for BOOST !!!!:sgrin::burnout:
