cjsupra90
- 1,023
- Lakeland, Florida - US
Ok guys here's the interesting strange running situation. Using very slow gradual throttle opening, the engine rev's all the way to the rev limiter with no problem. Anything faster or more rapid throttle opening and it starts to rev to about 3500rpm, then falls back to about 3000rpm at which point it sustains but its very broken up (for lack of better term). For anyone that is familiar with 2step rev limiter used in drag racing. It almost sound or seems like the first stage of the 2step is kicking in just to give you an example of what it sounds or seems like. The car is totally undrivable cause it starts to brake up as soon as you put any load on the engine at all. The engine does idle like there is absolutely nothing wrong and like I said before, with real light and gradual throttle opening, it will rev fine all day long and sound great but this is only true if there is no load on the engine (i.e. free revving)
The car is a stock 92 SC 400. I've check every bit of wiring for shorts or open circuits that I could think of that would be needed to at least rev out under load like MAF, TPS, and so on. We have also swaped out the ECU, MAF and TPS for known good units, plus tried the ones on hand in another car which they all worked fine. I've pulled codes and only come up with a 27 and a 29. They are O2 codes and the car is missing the secondary (post cat) O2's, but Im pretty sure that this has nothing to do with it cause the codes have been there for some time and the car has been running for several months without the seconday O2's. The car also had a tune up about a month and a half ago consisiting of Cap, Rotor, Plugs and wires, fuel filter, air filter and well oil change too but thats besides the point and I know all this stuff was done cause I did it for the guy myself.
In the end, it boils down to the fact that it ran fine one day and the next day the problem was there.
I've also checked ignition output which seems to be fine (i.e. doesn't seem to drop spark when it starts breaking up or anything that would lead me to believe that it was an ignition problem). I also checked the injector pulse width which seemed to be fine but did have a stange blip in it as I tried to rev the engine. What I meen is that when you opened the throttle fairly quickly the engine would start to rise and the injection pulse width would start to increase from about 3.1ms to about 4ms, then all of a sudden the engine would start to drop and the same for the pulse width. When it does this, the pulse width drops to about 2.8ms and then the engine starts to break up and at the same time the pulse width jumps up to about 19ms. This would lead me to believe that it was a ECU problem, but like I stated before, we've tried a different ECU and the problem was still there plus we've tried this ECU in another car and it ran fine.
Anyone have any ideas or things to check that I might be missing or forgetting about????
