Stand Alone ECU Group Buy
Zuffen
Super Moderator
All ECU's and looms were sent today except quadcamboat and Smithers.
I ran out of time.
The boss expects me to work on his time! Miserable sod!
thanhngo
I got mine as well...much smaller than expected but thats no problem :)
2M of cabling nightmare...kakaka...i hope not.
thanhngo
One of the thick black wires has no connector (just has terminals terminated with pins) So unsure of this, but I have asked Andy if this is correct. Will let you guys know.
thanhngo
Response from Andy:
"This is the trigger cable. The ECU is compatible with digital type triggers (Hall effect or optical) and reluctor type (as on your Toyota). They need to connect to different circuits inside the ECU so there are separate pins on the plug for the digital and reluctor inputs. So we supply this cable as separate and you can insert it into the pins you require
It's tricky to get them out so make sure it's the correct pin holes!
The wiring diagram shows which pins are which and I think the manual explains this also"
This forum member will spend the next week reading/learning the manual.
Smitherz
Woot! Got mine today as well. I'm very greatful to have this piece of the puzzle in my hands finally. Can't wait to put it to some good use. I just ordered a Lenovo T60 to program this sucker so I'm definitely feeling poor now. =]
sniper
Super Moderator
I got mine today! Man this thing is small, slight damage on one of the mounting ends, but looks ok.
