mshawari1 Member Messages 648 Location Riyadh May 21, 2006 #1 I need some help in: - Oil pan problem - hydraulic fan (should I install it ) - ECU wiring - Speedo meter conversion More detailed coming !!!
adxx Member Messages 71 Location Vladivostok, Russia May 21, 2006 #2 mshawari1 said: I need some help in: - Oil pan problem Click to expand... For your crown you need mid-sump. Also you need... eeee... 7 degree angeling to clear steering (search the forum area, it was here but with RH side japanese crown) - hydraulic fan (should I install it ) Click to expand... Originally uzs-131 uses clutch fan - ECU wiring Click to expand... AFAIK, you have something all-in-one wiring, so just get ECU for that wiring and that's all.
mshawari1 Member Messages 648 Location Riyadh May 22, 2006 #3 Thanks adxx, -About the mid-sump – its come with cs400 ??? from where I can get it ? - I get the ECU but there is four plug’s for the ECU and three more – what should I do with them ??
