- 5,636
- Sydney, Australia
I toying with the idea of selling off my supercharged engine.
One of my sons will be able to legally drive the car next June and the other a couple of years after that.
The vehicle as it stands isn't something I would want a young guy driving. In the wet it want's to swap ends without provocation and in the dry it's simply to fast!
Engine options to replace it are either another 1UZ (dead stock) or an LSx of some sort.
Going the 1UZ route is a simple engine swap and wire in the 1UZ ECU as I would sell my existing engine complete with ECU, water meth injection and intercoller set up. Using a 1UZ means the vehicles height must stay as is so the driver's side header clears the diff, but I would like to drop it a minimum of 50mm so it can get into my local shopping centre!
If I went LSx I would have more torque (than a stock 1UZ) which a 1900kg vehicle really needs, plus they are newer and more economical (which will count with the boy's driving it) but I have more fab work to do. Additionally the headers would clear the suspension so allowing me to take out the 50mm body lift. Bellhousing adaptors are readilly available for the swap.
What are people's thoughts and what do you think my engine would be worth? It has around 800klm on it since it was built last year.
These are the engine's specs.
Ross Pistons
Argo Rods
Sealpro rings
Kelford Cams
XR6 valve springs
nitrided crank
heavilly ported heads
Cometic head gaskets
Arp head and crank studs/bolts
Richwood ported intake menifold
Richwood 8rib supercharger drive system
Richwood manifold divider
Piston squirters
CRS sump & modified oil pickup
external oil cooler
Opcon 222 twin screw supercharger
LS1 ingition coils
4 into 1 headers
3" mandrel exhaust with high flow cats and mufflers
Frozen air 1500cfm w2a intercooler
bosch intercooler pump
Snow water/meth injection
Fast 90-mm t/b
Autronic SMC ECU - professionally tuned
15 litre water/meth tank
New waterpump and timing belt/idlers/tensioner
Cold air intake
There's more than $30,000 worth of parts in the above list but I don't expect anything like that for the engine.
Ross Pistons
Argo Rods
Sealpro rings
Kelford Cams
XR6 valve springs
nitrided crank
Piston squirters
external oil cooler
LS1 ingition coils
4 into 1 headers
Fast 90-mm t/b
Cold air intake
