OLD thread...
BUT...
I just had my accessory drive belt tensioner bearing fail.
Without a bearing available to R/R I called the local auto parts and they sold the assembly for $60.
When I got there and watched the screen I noticed just the pulley was available for $28.
Both sold under the Dayco brand. Both made right here in the USA^^^
No brainer right??? WRONG???
Same pulley OD, same bearing size, correct in NEARLY every way BUT...
The OEM pulley has a concave shape while the Dayco is flat. The OEM uses a concave washer design than centers itself and clamps the inner bearing race to the tensioner assembly leaving the pulley in place on the bearing. The Dayco shape interferes with the OEM washer locking the PULLEY in place. Upon startup the pulley did not rotate... the belt slipped over the pulley
Thankfully I noticed immediately and turned off the engine.
The washer would work with the pulley flipped over but the pulley doesn't fit the tensioner this way.
I looked at the Dayco full assembly and its pulley was slightly smaller in diameter. It would not fit the stock tensioner. Changing the entire tensioner is a PITA compared to the pulley and I prefer the Lexus engineered part anyway.
I was able to SOLVE this problem with a stainless steel washer, 17mm ID, 29mm OD, 3mm thick. The same spec washer with a smaller ID to fit the retaining bolt may be a better choice as I had to secure the washer with a couple tiny pieces of masking tape so it would locate properly. I used the above washer WITH the factory washer.
Hopes this saves someone the headache I just relieved...
NOW, if anyone has the correct bearing specs please post it.
