Sc400 vvti swap wiring help
Blue400z
So due to the limited info I'm finding on specifically the 1uzvvti out of a 00 sc400 I must ask here.
Doing 00 sc400 1uzvvti/sr trans in my datsun, everything physically installed, however I'm stuck on the wiring.
What I'm requesting is
Ecu pinout at minimum (for the 00 vvti comp)
Or just if someone wants to advise what wires need power/ground.
What I've been finding a lot of is ls400 wiring guides which the pin outs and wire coloring don't match mine.
I probably sound like a cry baby millennial asking for a silver spoon feeding. But need the help
I'd suggest you go here to ebay and buy the factory wiring manual.
http://www.ebay.com/itm/SHOP-MANUAL...ash=item33982ef1a2:g:VO8AAOxyBLBR8i1x&vxp=mtr
I have GS400 and LS400 vvti motors and harnesses and bought the toyota manuals off ebay for both models. The pinouts are the same but wire colors are different. The manuals are worth their weight in gold if you are doing a swap. You'll be glad you bought one. The illustarions are colored the same as the wire colors which make things so much easier too.
