removing steering wheel
V8TOY
North Shore,Auckland, New Zealand.
hey all i want to change my old steering wheel with my new momo one, but im not sure how to with having a air bag in it. does anyone know some step by steps to remove it without being knocked out by the airbag. thanx
does the new Momo have a Airbag? If not then you will have to swap back at each warrant or get it certed. to change remove fuse. unscrew- usually underneith then remove air bag cluster - carefully. and then remove wheel. I would not recommend doing this unless properly trained. Take it to a qualified person. Cheers.
Pull the fuse for the airbag system at least.
Weather there are any other steps I am not sure.
There is a write up over at Clublexus (search in the sc400/300 section for "steering wheel removal" and also at Supraforums. I believe both threads have pictures in them.
I also disconnected the battery for 30 minutes in hopes of discharging the system. I took my time and was careful not to short anything and I made it out alive ;)
