Pre-89 MA70-1UZ Fuel and Starting Systems - Electrical
LT_Chambers
Harford County, Maryland
Hi all, I just got a hold of the EWD for the SC400, and the starting and fuel systems are completely different from the MA70 systems, so I put together a diagram with some notes and was wondering if anyone could confirm/deny my speculations.
So basically, can you run the MA70 fuel pump with the signal from the 1UZ ECU that would be going to a fuel pump ECU?
And, does my starting circuit make sense?
Thanks.
Here is a bigger version of it:
Thanks.
Feel free to check out our wiring write-ups for the pre-89 MA70s at my project site (see sig below). It isn't as detailed as your diagrams above but should hopefully have some useful information for you.
Yea, I have been on your site frequently as I was putting this together. It was a little unclear to me how you did the starter system though. Thanks for the reply.
I will try and explain this weekend when I have time to review what I did =) Easy enough to walk out to the car and look it over since it is parked for the winter.
