Manifold swap
dantheman85
March
Hi guys. Got a mazda bongo with a 1991 1uzfe, I'm struggling with the intake clearance under the drivers seat. Which engine has the forward mounted t/b and will it bolt on to my motor? I think an ls430 has the intake I'm after. Cheers. Dan
Try spinning the manifold around.
They can be mounted with the Throttle Body on the opposite side.
There is a bit of fiddling around with the ISCV and wiring, but that's all part of the fun.
Interesting thought but I'll have the same issue on the passenger side, this is why I was interested in the front centre mounted tb of the 430.
Do you have room to cut of the T/b flange from the plenum and weld a tight 90degree bend onto it, then the old flange so the T/b is facing forward and sitting up close to the plenum.
I've cut away at the intake pipe and it "just" clears the seat. It works but it isn't very tidy, hence wanting the front tbh manifold.
